OPPO Enco X3 premium earbuds launched
Nairrk
Kannur, Kerala
FireShot Capture 747 - OPPO Enco X3_ High-end TWS Debuts at Half the Price of AirPods Pro • _ ...png
The new audio device features a two-tone design and is available in Black or White color choices.
Inside, it features a BES2700 chip and uses a combination of a 11mm bass driver and a 6mm tweeter. OPPO claims this brings a balanced sound with strong bass, clear mid-tones, and crisp highs.
FireShot Capture 748 - OPPO Enco X3_ High-end TWS Debuts at Half the Price of AirPods Pro • _ ...png
OPPO also noted they have enhanced the ANC by up to 50dB for zero distractions when listening.
The earbuds also feature AI Call Noise Reduction, VPU Bone Voiceprint recognition, and an updated anti-wind noise algorithm for that added noise control allowing users to have crystal clear voice pick-ups in noisy environments.
FireShot Capture 749 - OPPO Enco X3_ High-end TWS Debuts at Half the Price of AirPods Pro • _ ...png
OPPO said the earbuds also use real-time human voice identification to improve sound quality, increasing noise reduction efficiency by 200 percent. The sound quality during calls and music playback is further improved by a dual DAC and a three-microphone setup.
The new Enco X3 Premium features Hi-Res wireless audio transfer with a 1Mbps transfer rate. The LHDC 5.0 supports 192kHz/24bit lossless playback and uses Bluetooth 5.4.
OPPO also uses DYNAUDIO tuning and supports spatial sound for 3D effects.
There are gesture controls where you can pause/play music, handle calls, control volume, and a few hand movements.
Furthermore, it has a 58mAh battery per bud and a 566mAh battery in the charging case. This can be charged using a wired or 10W wireless (optional) charging pad.
Finally, the earbuds support an IP55 rating to handle some dust and splashes.
OPPO Enco X3 wired - CNY 899
OPPO Enco X3 wireless - CNY 949
As of the moment, it is currently available in China for order.
Innogyan/opposhop
