psychotropic
Oppo has launched a cheap version of its BD83 blu ray player. Featuring the same transport and mechanical bits, but without the Anchor Bay VRS technology , the BD80 looks like a stripped to the basics BD player. It still plays DVD-A and SACD and has 7.1 analogue outs. Still plays MKV off your hard disk. I am looking forward to reviews of this baby, because it's at a price range where it can take on the Panasonics, the Samsungs, the Sonys and the Pioneers.
The PR is below:
The BDP-80 is a full-featured universal Blu-ray Disc player that supports BD Profile 2.0 (BD-Live and BonusView), DVD-Video, DVD-Audio, Super Audio CD (SACD), HDCD, CD and other popular media formats such as AVCHD, MKV video files, digital photos and music. Sharing the same decoder and similarly optimized firmware as OPPOs award-winning BDP-83, the BDP-80 features fast disc load times, quick response to user operations, and robust audio and video controls. In contrast to the BDP-83, which utilizes an onboard VRS by Anchor Bay video processor, the BDP-80 design has been optimized for use as a digital audio/video transport, emphasizing the accuracy of its digital audio/video outputs. At the same time, the BDP-80 is versatile enough to be used as a stand-alone universal Blu-ray player, thanks to its full array of output connections and audio/video decoding capabilities.
For video, the BDP-80 features an HDMI 1.3 port that supports 1080p Full HD, 1080p 24Hz, Deep Color and Source Direct modes. Component video, S-Video and Composite video connections are also available for legacy analog displays. In addition to its faithful reproduction of high-definition pictures on Blu-ray Discs, the player can up-convert DVD from standard definition up to 1080p to maximize DVD picture quality. Its "Source Direct" output mode makes the BDP-80 incredibly well suited as a digital transport to feed into an external video processor, a high-end A/V receiver or display device with built-in video processing. Unique features such as subtitle shift and vertical stretch zoom mode makes the player an ideal source component for home theaters with 2.35:1 CIH (Constant Image Height) displays.
For audio, the BDP-80 supports internal decoding and bitstream output of the latest sound formats including Dolby TrueHD and DTS-HD Master audio. The BDP-80 also features a configurable 7.1-channel analog output that can be set as 7.1-channel, 5.1-channel, or stereo. When playing SACD, the BDP-80 can output DSD (Direct Stream Digital) over HDMI in its native format or convert it into high-resolution PCM. For compatibility with many legacy A/V receivers and DACs, the BDP-80 also provides an optical and coaxial digital audio output.
The initial setup of the BDP-80 is a breeze with its Easy Setup Wizard and well-written manual. Setup menus on the player can be accessed without interruption to disc playback. The front and back USB 2.0 ports enable easy access to music, photo and video files. The BDP-80 comes standard with 1GB of internal storage built-in so that no additional memory card or flash drive is needed to use BD-Live and BonusView features. Featuring a brushed metallic front panel and dimmable display, the BDP-80 fits nicely in any home theater environment, ranging from simple to high-end.
The PR is below:
