Panasonic LX850
Ashwin92
Kerala
1:40 amAugust 31, 2022
Ashwin
I am planning to buy a 55 inch tv with Dolby vision and Atmos and came across Panasonic LX850 which fits my budget. Is Panasonic still maintaining the same quality in their products? The built quality doesn't look much good. The previous models fx800 and gx800 had better build quality. Should I buy this model or can you suggest a tv under 70k with good brightness and upscaling?
Ashwin
Panasonic is fading these days in India. For that, you may try "Frame" in Samsung or Sony x80k or Hisense u6g which is a FALD for under 50k!
