Panny 42X20 . Its urgent
techie
India
Guys please help me fast about deciding Panny 42X20 . I am getting it for 36 k . Is it worth or is there any other 42 inch plasma in that range?
Also is Panny no1 . in plasma or should i consider some other company.
Plzz reply fast as i have to get it at most by tommorrow.
Hi got mine last week.In that price range this is a really good one and along with 3 years warranty its a good choice.I decided to get it after going through the 42x20d owners thread here.
Thanks alot dear :)
Tht really helps especially coming from owner.
One noob ques , is 42X20 and 42X20D same?
Thanks a lot. So should i go for this? I am just hesitating about burn in in plasmas. Is it alrite to go for it or LCD?
Can you control the lighting in your room? If yes then plasma is a good choice. But IF you cannot control room lighting then go for LCD. Reflection will kill the picture in a plasma. Be careful, these showrooms are very clever. They will show you test videos which contains very bright colours so it may appear that reflection is minimal. But take a test video clip containing some dark scenes to see what reflection will do to the otherwise excellent picture of a plasma.
Ya i can control ligtning in the room accordingly.So no problem there.
Ok final final ques leave aside room lightning part , taking into account all the aspects of both ,should i go for toshiba 40AV700 for 36k or panny 42X20 for 36k? Coz rite now they both look VFM.
if you are able to control the lighting then the plasma is a good buy.If u use it carefully in the breakin period it should come out fine.I havent noticed any IRs in the plasma so far as im following the breakin specs given in the 42X20 Owners thread.But the colors are real and pic quality is also vry good.
So regarding precautions during breakin period i should keep brightness at 0 and contrast at 50 in cinema mode?
I m having airtel HD dth so airtel logo is always there so have to zoom in so that no static image i.e logo is there.
So any other precaution ? and breakin period of150 hrs enugh?
you can get those info in the owners thread.The settings to be follwed at break in period.If u use the breakin slides the time period comes down.U can go through that thread and get indetail.
36 is a good price .. and yes panny is very good in plasma..
it was he price 2 months back... try to hard bargain more say bout 34.5k if not 36 is still decent..
indeed its a good plasma..
