Paradigm DSP 3100 V2 Versus HSU VTF1 Versus def tech pro sub 800
prasanna.kole
bangalore
Subwoofer Selection Paradigm DSP 3100 Vs HSU VTF1 Vs deftech sub 800 Vs Klipsch Syn12
Any reviews and comparison. planning to buy paradigm dsp 3100 but need your help before finalising.
Re: Subwoofer Selection Paradigm DSP 3100 Vs HSU VTF1 Vs deftech sub 800 Vs Klipsch S
Hi Guys,
Request help in finalizing between SVS PC12 NSD and SVS PB 13 Ultra for a 15*20*12 room size. Will appreciate quick response as I need to make a decession soon.
Thanks,
Amit
Hi Guys,
Thanks,
Amit
please check the threads by member name rana_kriti and pm him .
hi everybody
the results from dsp3100 are extremely dissappointing. there is a lot of noise in terms of chirping sound from the subwoofer for certain tones loud enough to screw up the home theater experience. i am in touch with kripa guys to figure out a solution. they have acknowledged and promised to look into the problem. i will keep you posted on this.
overall hold your purchase on dsp3100 till i get more inputs from kripa about the problem and solution.
prasanna
hi everybody
prasanna
Prasanna,
AFAIK paradigm use to be a decent sub. This will certainly be an issue with the sub, to me it seems the potentiometer(volume control) might be the culprit. I had similar issue over my sub and changing the pot fixed my problem. BTW, i would like to thank you for posting your review over the product inspite of your bitter experience. This means a lot for us. Thank you buddy:clapping::clapping:.
Latest Update on dsp3100
inspite of changing the circuit, problem is not solved.
i have asked kripa to change the entire subwoofer. waiting for their response. i feel the dsp3100 front port has issues, which is the wooden enclosure issue. you can hold your purchase till i get a root cause of the problem
Prasanna
tuned the DSP3100 sub with PBK Kit. the performance of the sub after tuning is awesome. basically bass is more tight in pass band. so PBK Kit is a must. i purchased PBK kit from US.
