Have been using Dali z3 with this amp. This is a serious combination, much better than twice its price range.
Nads are generally warm and laid back, look for speakers which are a little bright side of neutral.
Hi khetanbinay,
If you are ok with pre owned am having Rogers GS3 which I was using with NAD c352. If by any chance u r coming to Chennai u may bring the amp and can check.
