Picking Wharfedale surround set-up
I've just purchased:
Front: Wharfedale Diamond 10.1
Receiver: Wharfedale AVR-5110
I'm looking to get:
Center: Wharfedale Diamond 9.CS specs here - https://web.archive.org/web/2009071.../10/CID/56/language/en-GB/Default.aspx#detail
Surround: Wharfedale Diamond 10.SR
Subwoofer: Wharfedale WH-S10
I have a small room, about 10x10.
Would my speaker choices blend well with each other?
It is better if you can get the center from 10 series.. For surrounds you can change the series/brands.. Front speakers LCR are better if from same family...
From the stores I've asked, they don't have any 10 series center, the closest I've got next is the 101C
Diamond 101C | Wharfedale Hi-Fi
the drivers are 130mm compared to the 10.1's 120mm.
I'm concerned that the 101C would overwhelm my 10.1's?
