Pioneer rs-33
sam997
Hyderabad
I am planing to buy rs33 in hyderabad. Where can I buy this other than reliance digital?( reliance quoting 40k without any cashback or any other offer )
What are the other showrooms for yamaha in hyderabad ? (other than croma reliance)
My budget is 37-38k. I am going to use it for 70% music 30% TV + Movies.
So should i go with rs33 with good bass? or should I consider something else also.
What are the other showrooms for Yamaha in Hyderabad ? (other than croma reliance)
Have u auditioned it? Audition the Yamaha with Jamo combination they have or if your willing to upgrade later on go with some other combination else if you say end of story no more up gradation then buy the RS-33 for music its a good deal you will get good treble and bass only the mids are weak for a music lover like me i never worried so much about it.
But in hyderbad I think you can buy the seperate AMP of Yamaha with Jamo speakers and sub for the same price you have quoted from the grey market. Which is a better option if you are ok with greys
My bad.
I got impatient and just bought it for 38800. They ll deliver it tomorrow.
Is there anything I can do now?
Thanks for the tip. May be next time I ll use that.
I am going to use it for music most of the time. And I loved the bass in that so much I just bought it.
Thanks for the reply
By the way where are the grey market shops in hyderabad?
Hey friends..
There is a guy next to my home got an assembled 6.1 home theatre cost 25k. I askd him to play, it has heavy bass which can pullout my inner organs. When i used to cross his home, i can feel i crossed a theatre. Is the assembled HTs are gud? Life? Quality?
