pioneer sa 9800 binding posts upgrade with images
krell
Usa
i had pioneer SA9800, But the binding posts are spring loaded ones and i am not able to use good speaker cables. hence upgrade was done.
enjoying now:)
Looks like a neat Job. I also have a couple of amps where this could be done, will get on to it. Where did you get the new binding posts ? Locally or ordered online ?
ordered through ebay.com.purchased long back.very cheap and very high quality.
you can try.
regards
Bro.. Neat work..
Restoring Vintage Beauties are like Riding Bicycle :-).I would be good if you post pic with the NS 1000 and Pioneer.
hi, thanks for your comments. yes i upgraded the binding posts of both my yamaha ns1000m and jbl l112 and sansui au 717also. now i am using some high quality speaker wire for connection.
