Pioneer Todoroki
toocoolamar
New Delhi
Hey All,
Can any1 please confirm the price for pioneer todoroki.. i was quoted a price of 29k in delhi.. i.e. 5 speakers and its woofer.... would i be able to get a better price?
and which avr should i buy with it?
denon 1311 - 23k
onkyo tx sr308 - 19k
or a pioneer avr ?
thanx
In Pioneer Todoroki there is no capability of HD audio formats, So u better go for latest AVRs like Denon, Onkyo or Pioneer.
Yea I know.. I only mean the speakers and sub rs77.. I am getting those for 28k.. I was thinking of teaming them up with a denon avr.. So have u heard the speakers? Do u mean the speakers are not capable of giving out hd sound?? And is 28k a good price for the speakers and sub?
I think those speakers have been specially made for music systems. If you are going to use it for movies I wont recommend it. Those speakers have lot of high range than the mid and low i think so. So go for an audition and decide whether:licklips: it suites you. At the price range its a good one. After buying the item you should not regret for that product. If you put still more 5k u may get a good set of speakers.
u just told me that they are not compatible with hd sound?
and do u think i can get a better price for them than 28k?
and which avr would u recommend?
denon 1311 - 23k
Pioneer VSX520 AV Receiver - 24.5k
thanx in advance.
I have Pioneer 920K yet to configure with the speakers. I dont not more about the avr. From that 3 I prefer Pioneer or Denon. I think u can go for Pioneer since u have the speakers of Pioneer will be matching well and have the same support for the avr and speakers. These both AVR are 3d and has HD audio formats DTS MA and Dolby Tru HD.
hello, do not buy todoroki speakers. I already buy it and audiotioned it for one week. Our ears are bleeeeding. Buy speakers only from speaker specialists manufactures. Also buy only magneticaly shelded speakers. You can select avr pioneer or denon. Spend 40% for avr and 60% for speakers. Polk audio rm705 and pioneer vsx 820 is a very good choice for you....thx
Hi Amar,
I bought a pioneer todoroki HTP-RS30. 3 months back.
I am planning to sell it for a price tag of 32k along with the AV receiver.
VSX-320k which came along with the unit.
Contact me if you are interested.
My mobile number 9049001139.
Thanx for the heads up.. what problem are you facing with the todoroki? it would helpful for me if u could give me more details.. thanx in advance.
Hi Amar,
hey thanx for the offer.. if u purchased it 3 months back.. y r u selling it so fast..? and can u also tell me the price without the avr..?
Hi friend, Your selection of AVR is good.:clapping:. When it comes to speakers .Take some time to select the speakers. Some speakers may be good to hear for but after some time you may feel that the speakers make your years pain. get advice from specialist to buy speakers.
Hi Amar,
I bought this system as a an interim fix.
I have already bought a Polk audio dsw pro 660 subwoofer.
And would be buying an RTI A7 pair as floor standers alongwith demon 2311 avr.
Let me know if you are interestedin in buying we can workout deal for the package.
thank you ...I was almost on the verge of buying todoroki speakers ...thank you for ur posts..now i'll never look back towards pioneers {{ speakers only }}
