sujithblaze
Hi all,
Im planning to get an avr as step of setting up my home theater, the two avr's that im considering is the vsx523k and x1000. My max budget is 35k, so no Marantz :sad: , yes i know that the x1000 is a network enabled receiver. I request you guys to comment on the performance of both, MACC vs Audyssey MultEQ XT,Audyssey DynamicEQ and the 80 watts at 8ohms vs the 125 watts @6 ohms which should come around 70-75 watts @8 ohms, and an important thing the denon has a compressed audio restorer function is it available in pioneer as well? and once when i plugged in my usb to a pioneer vsx 823k it said no usb device
, so is there a special type of usb that i need to use?, will the denon have the same issue and there is a price difference of 10k, so my question is denon worth the 10k extra that i have to pay?
Kindly chip in with your valuable suggestions
Kind Regards,
Sujith
Kind Regards,
Sujith
