sujithkamath
Hello guys
I am currently having the following things. Need your help in setting up a projector. :sos::sos::sos:
1. A guest room (10' x 10') which i will have to fight with my wife for using it to setup a projector hyeah:
2. A Philips DSP 65e which i had bought assuming i will use it to my 40" Sammy LED but turned out i dont have a Coaxial cable and no converter available. So stuck it to my STB. Planning to use it with the PJ
3. Rs.50k in hand; very tight on budget.:sad:
4. Immense desire to have a good PJ which will enable me watch HD movies over weekend mainly out of USB hard disk.
From the posts i saw most of the votes have gone to ACER H5370BD.... And i think i might go with it, still welcome any other suggestion for my budget
Questions:
1. Since i dont have any friend going to US to buy PJ for me, i will have to order it from amazon.com and ship it using their own service. I tried going till the end of their cart but could not find how much more i might need to pay.
Any idea?
Amazon Link
2. Any idea on what else do i need to buy alongwith the PJ. I dont think i will be using 3D much. But surely will buy compatible 3d glasses down the line(not immediately)..... HDMI cables? do i need them if i will be watching mostly from USB stick?
3. Read somewhere that i might need amplifiers. No idea about this. ????
4. I assumed blindly that i will use the Philips DSP 65e. But not sure if i can. Can i? please say yes
5. Not sure if i need to use ceiling mount as i am not planning to spend on buying a mount/getting artificial ceiling done.
6. Off white wall.... No screen required I guess. What say?
7. Do i need to do any kind of setups to the room? I am sure i can use good curtains and reduce ambient light. any other suggestions? if yes, any vendors in Bangalore?
I am in a very initial stage of deciding on the PJ. Any advice/suggestion will only help me in realizing my dream for a home theatre.:signthankspin:
Questions:
Any idea?
Amazon Link
