Planning to buy Onkyo 3500 from Dubai
sjason
India
Planning to buy Onkyo 3500 from Dubai I have few questions.
1. Is it safe to carry the product in the flight from dubai?
2. Do we need to pay any TAX in the costumes..?
If any one have any experience buying this product in dubai please share.
Thanks for your reply in advance.
You can bring products upto Rs.35,000/- without customs duty. If the price is above this then you need to pay customs duty.
Also check the weight of the full HTB package. In flight they allow near to 30kg only. Any extra weight they charge a lot.
Thanks all for your Suggestions...
One last question..
What is the major difference between onkyo 3500 and 5500
sjason, If I remember right, the 3500 comes with passive subwoofer. The 5500 comes with active subwoofer. So if you have plans to upgrade the subwoofer later and want to use the LFE out from AVR, the 5500 would be the better option.
kittu, core, HTIBs are much cheaper in the middle east, be it from onkyo or yamaha. The 3500, yamaha yht 196 etc can be had for around 15k inr, which would not be subject to customs. The weight of the package would be a problem though.
Edit: Though the higher model might come with an active sub, the subwoofers sound quality is not exactly better.
With the previous gen, i.e 3400 and 5400, another difference was that 3400 was 5.1 while the latter was 7.1.
