Planning to buy Sony Bravia X330
nilesh636
kolkata
HI Guys
Please suggest
I am planning to buy Sony Bravia X330.
Please suggest is it a good TV. ?
my TV viewing distance is 9-10 ft.
is it ok to buy a 32" television.
Thanks in advance.
I think you mean 9-10 ft. :) At that distance, at least 40"+ TV is recommended. You should specify your budget also.
The model you mention is (32)EX330 and not X330. It is a 720p Direct LED TV. It will cost you around 30K retail (MRP=32,990). If that is the budget you have in mind, I think that you can look at some Toshiba and Sharp models also which will be cheaper and better. But basically, I think that you should increase the budget and aim for 40-42" TV which will do more justice in the long run.
hi
thanks for the quick reply and pointing out my mistake. its 9-10 ft.
i am getting that TV for 24000.00 Please suggest any good FULL HD 40"TV.
If you are getting the TV for 24K then check that it is not a display piece. Otherwise, it is a very good deal and you can go ahead.
Amongst 40" Full-HD LED, you could consider Toshiba 40PS20 (43K), Samsung 40F5100 (52K), Sony 40EX430 (54k), etc.
