Planning to buy V20 in Kerala - Help
smithakp
london
I am based in UK and planning to buy Panasonic 42V20 or 50V20 for my parents in Calicut, Kerala.
Can anyone suggest a dealer's name? I phoned and emailed Panasonic in Mumbai, but they are not at all helpful.
Or is it better to take it as accompanied baggage from UK?
Any help is appreciated.
S
smithakp, a few months back I had tried to source the same here in Cochin, Trichur, Kottayam etc. No luck. Finally, went to Bangalore and got it with Kittu1977 s help.
S
Hi Smith
Take a token and join the long list waiting for their TV of choice in Kerala. I had been to a Panasonic store in Cochin, on the bypass, and they have a couple of models that they target and most probably will not have what you want. Moreover I think the panasonic store closed shop. As titus & kittu suggested try get it from bangalore. You should be able to get service back, if not in calicut at least in cochin.
Hi All,
Thanks for your info.
Rang QRS, Nandilath, etc to no success. They do not stock Panny at all, which is strange!!
Rang Panasonic brand shop at Trivandrum who do not have stock either. Not sure if there will be any stock and the price they quoted was not less than 70k.
Is it possible to buy from a Bangalore dealer who can ship over to Kerala? Any recommendations? If so, do Panasonic provide services in Calicut? Cant find any in their website.
S
You can talk to Modern world , Domlur branch in bangalore. They do ship to other places with extra cost.
