Please guide me regarding setting up Dedicated power line for home theatre
Dr.vinayaka
Shimoga, Karnataka
Good morning
Wishing you all happy Deepavali.
Greetings from Shimoga.
Please provide me guidance regarding dedicated power line to home theatre
1) what wire should be used from main line
2 ) MCB - how much capacity
3) Any other thing to buy
I already have isolation transformer, digi 200, power base from Hifi mart.
I want to get clean power for my av gear.
Please guide me. Waiting for your response.
With regards
Vinayaka
Good morning
With regards
Vinayaka
1. Thicker core is better. Depending upon the budget there are very expensive brands like LAPP or mid range like Supra which you can use
2. MCB capacity depends upon the load you are consuming. Give a 50% safety factor and plan for future usage too. Add the peak KVA for all equipment and add a 50% to the same.
3. Adding too many circuits is not a good idea. A voltage stabilizer is generally not a good idea for AV equipment.
You could use a power conditioner or a CVT or a pure sine wave UPS to isolate power fluctuations. There are multiple threads and google to help you understand which work best for your needs.
