Hello All, I have a desktop with the attached specs.
Can you suggest a graphics card, and other changes to achieve the following requirements please:
1. Bitstream audio to avr is a must.
2. DTS HDMA and DOLBY TRUE HD from downloaded BR rips.(need not worry about this if bitstream works i guess)
3. Bitstream audio from Netflix etc (what ever best audio they stream, like DD+ etc)
4. 4K video is not a compulsion, but whatever best FHD video possible.
5. 3D video capability (only if possible in a budget)
This is only for music and movies. No gaming.
(I am not sure about the power supply in my Intex supernova CPU cabinet. If needed I will open and check)
Later, I will add a blueray drive to play physical DVDs and BR discs (if i feel it is needed)
So I have to plan a suitable graphics card.
I found The following graphics cards in budget, but not confident on which one to pick:
1. Zotac GT 710 2GB DDR3 Zone Edition Graphics Card (3.1k)
2. ZOTAC GeForce® GT 710 2GB DDR5 ZONE Edition Graphics Card (3.6k)
3. Zotac Nvidia GT 730 2GB DDR5 PCI-e Graphics Card (5k) (best seller?)
Is there any one in Hyderabad who can build a htpc for me please?
(please ping me separately)
Thanks & Regards,
Naveen
9849771662
Thanks & Regards,
Naveen
9849771662
