hi guys,
i am moving to india at the end of this month. I have become a regular member of this forum recently due to my move to india and also to touch base with some Hi-hi enthusiast like me.
I am facing a massive constraint which i am sure you would have come across.
I have following system and I need power management solution for it as I will be based out of Delhi and power is not trust worthy at all:
1. Denon AVR 3808A
2. Roksan Kandy K2 integrated with power output of around 120 to 150 in 8 Ohms (either of them not sure)
3. JL Audio Fathom f113 Sub which is 2500 RMS
4. HTPC with 650 watt PSU
5. Panasonic 50' full HD plasma
I would like to request about throwing somelight on what solution in need for best power management and from where I can get it. I would kidly request for 2 different version money wise(Medium range and high range)
All my sytem is arriving around 2nd week of August and I need to know all this before it arrives so I can also concentrate on some room acoustics.
So far people have thrown idea on UPS and Servo Stabilizers but I have not had concrete understanding. I would appreciate if you could also add where it is possible to buy the stuff.
My majoy concern in my sub and TV which are expensive then most of the other items and definately deserve some respect.
I will appreciate your help.
kind regards,
swatantra
1. Denon AVR 3808A
kind regards,
swatantra
