Polk Audio TSx 150C is a center channel speaker manufactured by the highly rated Polk Audio. Its beautifully compact loudspeaker gives detailed, heavy center channel performance. For easy placement in any system, it has reversible enclosure. The Polk Audio TSx 150C center channel speaker rear firing fared bas port helps to minimize port noise and blends low frequency response smoothly. It is manufactured using high quality materials and advanced manufacturing techniques for exceptional performance.
Polk Audio TSx 150C main feature is its TSx Series bi-laminate composite driver cones that are perfectly tuned to Dynamic Balance process to produce natural and smooth sound. They are super stiff, lightweight with damping that is exceptional for low distortion and high efficiency. Its all-MDF, amiable and reversible enclosure is non-resonant and it features a thick baffle of 5/8 inch for heavy duty performance.
Polk Audio TSx 150C is timbre matched and is designed throughout with the same components to achieve seamless speaker to speaker blending effects especially in multi-channel systems. It has professional style five-way, gold plated, binding posts that provides the most secure connection options. In addition, it has ported bass reflex design.
Other impressive features of Polk Audio TSx 150C center channel speaker include sensitivity of 91 db, 8 ohms impedance, wood-grain vinyl finish; its dimensions are 20 inches x 8 inches x 7 inches and 14.6 pounds. Its recommended amplifier power is 20 to 125 watts. It has a frequency response of 63-24, 000 Hz.
Polk Audio TSx 150C Center Channel Speaker
Polk Audio TSx 150C ReviewIn our opinion, Polk Audio TSx 150C is a good choice of sound system because it has a higher sensitivity rating than previous speakers. It perfectly blends with the sides and it handles TV and movies very well.
In conclusion, Polk Audio TSx 150C is a product that will be great for your entertainment and sound system. Its price is reasonable and its unique features, high sensitivity and frequency assure you of high performance. Its size is friendly and its quality materials and advanced techniques used in its manufacture increases its period of use with minimum maintenance.
