Well i m new into this world ...but a great fan of listen music n watching movies ...looking for superior audio sound experience ... Budget upto 100000 rs ...any1 who tried dolby atmos home theater ...can u share ur thought ...onkyo home theater is available ...but read many negative feed back about the company .. i was going to by sony n9200w later on figure out much better option available but again read some of review here that yamaha sounds better
....i just want to buy dolby atmos future enable sound system ..u cud suggest me reciever n speaker or entire combo home theater ...desperately looking forward for ur reply ..ur help will be appreciated thanks guys
First things first. How big would be your room where you intend to install the Home theater system. Can you install speakers on your ceiling? What would your source be? TV/ Bluray/CD Player/ Media Player or PC? Will you be comfortable running wires all around the room to place the respective speakers in those places?
It's decent budget for a home theater, So take your time and Please do not hurry.
As far as receivers are concerned, Likes of Yamaha,Denon,Onkyo,Marantz are standard staple brands.
Speakers come in all sizes and shapes that fit your room size and how loud you may want them to blast.
Staple brands for speakers are Wharfedale,PSB, Q acoustics, TAGA, Morel, Jamo, Dali and so on.
One key point to remember. Music sounds best with 2.0 or 2.1 systems.
You can also think of building the system components wise, Like getting a receiver and front Speakers and then add on the center surrounds and subwoofer. It takes time and patience to get the right combination so never hurry. Do go and audition the systems with preferably the same receiver you intend to buy and the kind of music/movies you like.
