Pls suggest a good ups for 50 inch led tv
venkatg
Tamilnadu
The place i live has frequent powercuts.In our apartment we have generator so all i want is just 3 or 4 mts battery backup time just to switch off the tv safely when the power fails suddenly.Any good brand under 5000rs.I have absolutely no idea about this so kindly give your suggestions,also if i get a ups is there a need for stabilizer?
These are the things i want to connect
50 inch Led tv
Tata sky HD setup box
Asus media player
600VA offline UPS is enough. Look for brands like APC.
Are these good?
APC Back-UPS BX600CI-IN UPS 600VA: Amazon.in: Electronics
http://www.amazon.in/600VA-APC-UPS/...&qid=1388203343&sr=8-1&keywords=apc+600va+ups
What is offline ups?
Just now ordered v guard crystal plus stabilizer.
power->stabilizer->ups->Tv. Is this ok?
Not much fluctuation here so if i get ups ,is there a need for stabilizer?
If u find any other online link please give that.Right now i don't have home theater or music system so all i need is a good ups to connect tv , set top box and media player
Offline UPS will switch to battery mode only when there is no input or when the voltage is beyond the specified lower and upper limit. Most entry level UPS are offline model. The output is square wave when in battery mode. They are comparatively cheaper. There is also line interactive UPS which has built in voltage stabilizer so that you can avoid another stabilizer. The output wave format is usually quasi-sinewave. For pure protection there is online UPS, but very very expensive.
Since you don't have much voltage fluctuations, you can avoid the stabilizer. I suggest you to look for a line interactive UPS.
