senthil83kumar
I recently bought a Yamaha yht-196 HTiB and found the passive subwoofer it came with too under-powered for my living room. After looking at posts in AV forums, I understand that I can improve subwoofer performance by adding a subwoofer plate amp (thereby making it active). I have a few queries in this regard and hope you ppl would help me out.
1.Any suggestions on which amp I should go for? The subwoofer is 16cm cone type with max power handling of 100W
2.Can I use the subwoofer preout (since plate amp is gonna amplify signal anyway) and cut power to subwoofer in AVR for better power distribution to the other 5 speakers?
Any suggestion would be really really helpful!
Thanks & Regards,
Senthil C
Thanks & Regards,
Senthil C
