plz suggest 42 inch plasma in 50k
vikcoolboy4u
delhi
hi i m goin to buy a plasma i need
1.42inch screen or if in my budget more then 42 inch olso
2.full hd nd if 3d cum in my budget it will b plus for me
3.i hv sorted out p42u30d plasma whch is in my budget ny othr plasma den plz suggest.
4.panasonic is my frst priority bcs it is the best in plasma may b m wrng
thnks in advance
thnks in advance
Demo the Samsung 51D490 its a good 3dtv available for 56.5K.
i hv jst chkd dat this model is not full hd i want full hd 3d if it comes in my budget sam51d550 is full hd hw much it wil cost in delhi?
im seeing ur hometheater room pic it awsum yaar lots of thing r there in ur room projector 3d tv 7.1 speaker nd etc etc ...whch tv r u using?
mandeep whr ru frm?.....i think ur room is soundproof mi rght?...hw much it cost to make room soundproof?
VikCoolBoy - Do NOT use SMS language here. Form your sentences properly. Moderator.
You can get "Panasonic 42 Inches Full HD Plasma TH-P42U30D Television" or "Panasonic 42 Inches Full HD LCD TH-L42U30D Television" in Rs.41920 from flipkart.com. Hope this can help you.
thnks in advance
Hi, Let me first congratulate you for buying a plasma over LED/LCD, perfect choice!!! Now let me just clarify some details on panasonic plasmas. Panasonic runs the following series in Plasma:
2010 line up : VT20,V20,S20,G20,U20,X30
2011 line up : VT30, ST30, GT30, UT30, U30, X30
Neo pdp : Based on several breakthrough innovations, VIERA NeoPDP takes flat screen TV to the next level. VIERA NeoPDP TVs has an ultra-high dynamic contrast ratio of over 2,000,000:1 thanks to a newly developed discharge gas. This translates into deep, true black tones and brighter whites for more vibrant and lifelike pictures with every film or TV programme. To ensure that sporting events, action films and gaming picture quality is smooth and without judder, VIERA NeoPDP employs 600Hz Sub-field Drive with Intelligent Frame Creation Pro. Based on 600Hz technology, the internal processor creates 600 Sub-fields, afterwards an intelligent algorithm selects the best ones to optimise the flow of motion on the screen.
As you can see, its only makes sense to buy a panasonic plasma with neo pdp panel. This is why panasonic is the king of plasma tv's. No doubt they make the best plasma's, provided it has neop pdp on it. Unfortunately not all models do. The following models support neo pdp:
2010 : VT,V,S,G
2011 : VT,ST,GT
U and X series do not, so I would seriously advise you to stretch you budget for V20 which was and still is one of the best, if not the best 2D tv's in the market. It was also rated as the best tv for 2010. However, should you still want an entry level tv, then you can look at Samsung plasmas. They do better entry level tv's than pan U/X series.
But, please try your best to get the V20, even though a bit expensive, it is worth every penny, you will not regret it!!!
thnks harry nd aaksh i knw aaksh bout all these series hvng neopdp nd nt hvng neopdp bt v20 is expensive nd out of budget in delhi it cost around 63 to 65k...nywaz thnks ur opinion ...harry will flipkart deliver the product all over india free shiping ....nd if i buy from this site will it b trustable?
is 51d490 avlabl on emi online shopping ?.....plz teeme i hv credit card i can go directly to the shop bt my credit card is nt frm delhi address so they say they cn nly give emi option to the delhi address dats y goin for onlin emi flipkart is providing emi 3 nd 6 mnth bt 12 mnth will b beetter wth 0%intrest nybdy knows ny trusted onlin ewmi option site
If you have citi bank card, letsbuy is better.
Online Shopping - Buy Mobile Phones, Cameras, Laptops @ Lowest Price - Letsbuy.com
Know More About Emi
You can find 5-10% discount coupons online.
Thanks dear
Last month i replaced my 32 inch, Panasonic LCD TV with Samsung 51D490 3DTV.
Added a POPCORN HOUR A210 media player along with WDTV Live.
Really enjoying my HT even more Now-a-Days :cheers:
VilCoolBoy : This is your second warning against use of SMS Language. If you do not write properly, we will ban you from HFV. Moderator.
I am from Mohali, near chandigarh.
Yes it's sound proof, i spent around 40-45K for doing the same along with some woodwork. Sound proofing allows me to enjoy movies even at high volume and there is no sound interference from outside also like sound of nearby generators, traffic etc etc. Really enjoying my HT now after this, thanks.
