Hi Everyone...need some help.
I currently have a Yamaha 5.1 amp (RXV 595 - 75 W RMS @ 8 Ohm) connected to a Bose 4.2 direct reflecting bookshelf speakers. I am looking at upgrading my speakers to floor standing (preferably 3 way) and have been listening to a few. Here is where I need help;
- In your experience which speaker would be better if I listen to a lot of rock/blues/jazz. The RTiA7 or Wharfedale Diamond 10.7 or Jamo C605?
- The RTiA7 is 300W RMS will my amp be able to sufficiently power it? It is 75W RMS @ 8 Ohms
- Are there any other speakers in the below Rs.60,000 range that you feel would be better than the ones I have mentioned?
- If I was to buy the RTiA7 and wanted to change my amp to a stereo amp which one would you suggest below Rs25,000.
I know these are a lot of questions
...any help from you guys would be really helpful.
Thanks,
Jasdeep
Thanks,
Jasdeep
