Hello
All
The old members might recognize
For the new members my name is Ali
"SoundFoundations"
I have sporadic requests from members to build them an amplifier cabinet ( High Fit and finish )
especially something that can dissipate 200w per channel in class AB
The v4h and hiraga and the pass series developed a lot of interest with serious diyers
Serious diyers were looking for a cabinet with a very good fit and finish as opposed to the DIY boxs made of wood
i took up their requests and have come up with the following
Amplifier Case – SFC25
The SFC25 is a Fully Cnc machined All Aluminum ( T 6069) Amplifier cabinet/Chassis for Diyers who do not skimp on anything .The case comes with heatsinks and drilled panels for connectors as shown.
You now need only the electronics ( PCB + TRAFO ) and connectors and you’re DONE
The cabinet heat sinks will accommodate up to 30w pure class A per channel or up to 250W class AB per channel according to Indian weather.
if there is intrest you may contact me
@SoundFoundations
The product will also be listed on our freindly neighbourhood hifimart soon
Pricing is something we respectfully ask members not to disclose on a public forum
All
"SoundFoundations"
- Front panel thickness – 8mm
- All other Panels – 3.0mm
- Heat sink size – 145 mm high and 300 mm long , Thickness of base 10mm
- Cabinet Dimensions -( Outer )– 430mm (W) * 373 mm (D) * 150mm (H)
- Cabinet Dimensions - (Inner Space for population) – 330mm (W) * 360 mm (D) * 140mm (H)
- Weight – 11.5 kgs
- Color - As shown
@SoundFoundations
