Power Conditioners
CryptBala
Chennai
Hello Everyone,
It seems like the decent Power Conditioner within budget would be Furman if I am not wrong but the problem is most of the Furman Conditioners I see in Amazon doesn't come with Type D electrical plug. Other conditioners such as the Isotek or the ps audio are way out of the budget. Any decent recomendations are welcome.
My current set up is like this I am using a Solatek TV Guard Isense on my main outlet from there its connected to the vguard crystal plus and then to a UPS from there its connected to the Gold Surge protector from Belkin the final place where I tap for all my requirements.
You can try vertex servo stabilizer and rontek power conditioner. Vgaurd isn’t the right product for Stable voltage. Refer the below link for details on both vertex and Rontek
I've used power line conditioners since the late 80's all I can tell you is any line conditioner is better than none, Adcom ACE-515, Sima LF-2, Inouye S.P.L.C. they all work A basic unit will have M.O.V protection which helps protect but not condition. Do you want protection or conditioning? Protection can be had for a reasonable price.
