Problem Shooting in Onkyo Receiver
filmbuff
kolkata
Hello
A Problem arises in my Onkyo HT-S3200, 5.1 Receiver. After switching the machine the sound portion remain Mute. Though its not muted from the remote. The all wires of speakers are ok, the reading in the screen of receiver ok, but the sudden thud or the sound thea comes from the all speakers remain silent. Hdmi of dvd player is connected with the LED port.
Somewhere the sound is muted whether in inside or may be any cables may be detached from IN to OUT from tv to receiver. Only the Coaxial video cable is not attached with TVs IN to Receivers OUT.
Kindly give the suggestion to revise the wire connections or to release any button from remote or manually.
Or really there is a problem inside the Receiver.
I will be thankful if you Kindly give the solution.
