Projector Paint for the wall
petes
Guys - Recently i brought a Projector, and right now the color of my wall is little dark.
Is there any particular paint that i can apply, so that the quality of the projection will improve.
Thanks!
Have you tried the background color option in your PJ? Some PJs provide that option where it correct the projected image according to the background color
Else, go for a screen or pure white background in mat finish
Thanks!
I used this as projector screen paint. Got it from amazon.in.
Thanks!
why dont you try getting a screen instead of spending on painting? Also, a very important thing that enhances the visual is the black border around the picture. This would make a lot of difference in the perceived picture, compared to no border at all. just my 2 cents :)
Thanks for all you suggestions..I fell that wall is more lively than screen..Let me think about it!
You can very well use wall as a screen. Just make sure the paint is of good quality & closer shade of white and Matt. Else it will reflect hot spots. I am using it for many years without any refractions.
I preferred wall for 2 reasons,
We don't use PJ all the time. So I didn't want my living room wall to look differently by permanently fixing screen
There are no simply no wrinkles or curves for wall as compared go hanging screens from my friend 's. Also hanging screen may wobble a bit when you start fan.
