Recommendatio for Replacement Cable
skt11
Tirupati
Hello Every one,
I have a Hifiman 400i & recently its cable stopped working. I am looking for replacement cable, but in Amazon, it costs around 5000. Can find in Aliexpress for 1000, but not sure if it will reach me or not. And est. delivery is 30-40 days
Also, can the below things work & still costs me around 1300??
1. https://www.amazon.in/FENTICO®-Stereo-4-Pole-3-5mm-Adaptor/dp/B089FC5QTK/ref=sr_1_4?crid=V2Z5UGI2MVU7&dchild=1&keywords=2.5+mm+to+3.5+mm+cable&qid=1594341923&sprefix=2.5+mm+to+3.5+mm,aps,301&sr=8-4
2. https://www.amazon.in/Boat-Indestru...ords=3.5+mm+audio+cable&qid=1594342045&sr=8-3
3. https://www.amazon.in/World2view-Universal-Earphone-Headphone-Extension/dp/B07BF6JQVS/ref=sr_1_14?crid=10Q0GNK9ZHMF1&dchild=1&keywords=3.5+splitter+2+male+to+1+female&qid=1594342234&sprefix=3.5+spli,aps,294&sr=8-14
Or can you guys guide me from where i can get good quality cables?? I would like to spend upto 1500 for the cable. Thank you
And the specifications are 2.5 mm *2 & 6.5/3.5 mm
<merged by moderator>
If I understand correctly - you want #1 to attach to your headphone inputs, #2 to run from #1 into #3 and that to your player! The answer is YES, theoretically in combination it should work fine. I see no problem, theoretically.
However, please do understand, you are creating multiple links between your source and your headphones and it "MIGHT" have a huge impact on sound, as there is bound to be signal loss between so many 'joints'. Budget constraints considered, this will certainly be a quick fix.
Thank you
