recommendation for amplifier
jeckary
LA
I wan to have an amplifier for my PC, I usually use it for music and movie with my earphone, so it would be better that if this amplifier can support earphones.
I have found such one online, but it seems that this one only support for the output of earphone, I don't know because I am totally an amateur of speakers.
so, I am not sure this whether this one can support for speakers, or if you have any other good recommendations for, please, my budget is about 200$.
If you plan to use with Headphones only then look for a decent Headphone amplifier. With the budget you mentioned there are plenty of options available to choose from. Don't know about your music interest but anyway include some valve amps in your auditions.
If you can go DIY way (or can find somebody whio can assemble one for you) , there are many DIY kits , schematics etc available .
Hope this helps.
SUhas
