Recommendation for HT Rack Unit Designer and Builder in Bangalore
rajivaryan1984
INDIA
Hi, I am looking for some professional services in Bangalore who can look into my HT Unit in my living room and suggest proper design for the Rack and help me build the same furniture...Any recommendation from the FM's here will be very helpful/
Check the av racks from sound foundation and you can take one or contact Amit from Indiq audio. They are now building racks for av equipment.
Been to Indiqaudio for audition and saw one of their rack there. I really liked their craftsmanship. I think they also do custom design as per requirement.
But very costly 1.6 L - 2.0 L
You can try solid steel rack available for 32k . The price would differ with various dealers and look out for the best deal.
Or if you can get a Salamandar audio rack at a cheaper rate, then that would be a great choice since the shelf height are adjustable. You get designs with 3 or 5 shelves in different finish which were available on Amazon.
Salamander Designs Archetype System Modular Shelving Audio Stand (36", Natural Cherry) https://www.bhphotovideo.com/c/prod...r_designs_a5_c_archetype_5_0_audio_stand.html
Many times these standard racks are open on all sides and is prone to dust getting accumulated all around the equipment. Open racks also make wires look ugly and spoil the decor
All good decor & aesthetics wise but one of the prime reason why many equipments die a slow death is due to overheating. Whatever be the design , ventilation is a must & nothing does it better than fully open racks. Closed racks are good if done thoughtfully with ventilated panels on both sides & removable front flaps when being used
A ready made media cabinet will work fine as long as ventilation is considered. But it lacks flexibility. My own designed and carpenter built living room HT rack, while still stylish has reached its holding limit and will need chopping and rebuilding to accommodate any future additions.
Having learnt from that expereince, I have stuck with modular open rack systems for my 2 channel system. And the advantage with using racks from dedicated companies, is that the system is expandable as box count grows.
Iam using sound foundations epsilion center rack and matching power amp stands. The advantage is that the sound foundation, cerabase isolators can be slotted into the system to achieve rack level isolation for each component placed on the rack. So no ugly looking footers are required under the boxes Iam very pleased with the excellent build, quality and design of these. I also use matching speaker pedestals for my Diy floor standing speakers. So everything looks aesthetically cohesive.
Also, lot depends on the location of the rack and how accommodative high command is :). Rack in living room and having lots of boxes in open shelves is like playing with fire, you never know when you will be thrown out along with the equipment. A custom-designed rack that accommodates all the components, optimizes the available space, and provides sufficient ventilation is the ideal solution, in my opinion.
