Red Amp Camp A: the build
kaushik
Hi all,
Being a diy enthu with audio hobby always I find ways to hunt low cost ideas so that pretty good looks and sound can be achieved.
This Idea shows how almost decent casing can be made with scrap metal chasis
For amp camp stabilizer cabinet will also do.
Remove metal. On one side with metal cutter.
Add the screw less metallic front.
( fixing this I will reveal if lot of demand)
The chassis costed me next to Nothing ( with swich max 260that include glowing power button.)
- front metal sticker on acrylic was used
- chassis was from a small. Solar lamp system.
How looking for humble member or sellers
For irfp240 and ztx450
Probably will basic 5w version.
Or shall I make redux version 8w?
