Hey again...
I'm planning to buy Onkyo HT-S3300 and use my PC as HTPC.
I've got Palit 9600GT and Gigabyte G31 mobo
So i've connected internally via 2-pin spdif cable which i got with my graphics card. I can get the audio on my Sony LCD (40EX400) via DVI->HDMI adapter now which is decoded in PC (to PCM, i guess).
I want to ask which audio(s) it'll pass through?
On my search on Google I found this: 2 channel stereo and compressed 5.1 channel...
So I guess this means: 5.1 AC3 640kbps & DTS 1.5mbps will be passthroughed <-- Please someone confirm this!!!!!
and lossless audios like DTS HD-MA/True-HD/LPCM wont be bitstreamed...
I'm in least preference of buying an audio card now if for now 5.1 DTS/AC3 passthrough works with my current setup.
If it doesn't works, then which Audio Card is recommended for my setup considering I've only one PCI Express x1 slot and one PCI slot. So it should be compatible with this
My budget for Audio Card is as least as possible but at same time good and efficient card. Is Xonar DX necessary to get better sound via passthrough, i guess xonar dont need to process audio in passsthrough, so cheaper ones then that will also do.
Thanks & Regards
Thanks & Regards
