I would like to buy an inverter. Load is
3 fans
3 tube lights
1 tv or 1 computer
I zeroed in on Sukam inverter 850 VA (Shiny series) or Luminous inverter 875 VA.
I have contacted the dealers. They have quoted the following prices:
Sukam 850VA(Shiny or falcon) + Sukam battery (100 AH) + installation ---> 13,000 rupees
Luminous 875 VA + Luminous battery (100 AH) + installation -->
13,000 rupees.
Dealer has suggested luminous is better compared to sukam as it has
1. MCB technology i.e the fuse gets switch off during overload. While sukam has fuse which may burns out during overload
2. Luminous 120 AH battery is of tubular technology and it is more reliable. With luminous 120 AH battery he quoted the total price (inverter + battery + installation) as 14000 rupees.
Also service wise they are both same.
I have the following doubts:
1. Is sukam batteries are reliable. I found in internet they are not so reliable and doesnt have good battery life
Finally do i need to go for sukam shiny or falcon inverter + luminous 120 AH battery. Can you please suggest. I was very confused which ones to take. Can you please reply me soon. Its urgent for me. Thanks in advance.
-- Rohit
3 fans
3 tube lights
1 tv or 1 computer
13,000 rupees.
-- Rohit
