Replacing Bluetooth Adapter
Manoj Nair
Hi I'm using a Pulz Pre Power Combination for my music .
Model Pulz RS 100 Pre Amp
Pulz HA 400 Power Amp
Speakers are Vintage 3 Way 10 inch Pandam.
The Pulz Pre Amp is connected to TP Link Bluetooth Adapter and I stream music from my Laptop ( Spotify).
There is no DAC in the connection.
Lately the sound is pathetic and very low when I use the TP Link Bluetooth .
I think I would need to replace the Bluetooth.
Could somebody advise which Bluetooth should I buy or any possible solution to the issue.
Would surely appreciate a feedback / advise.
Manoj
Manoj
Logitech would be good. Infact the Local Chinese brands available at Lamington road for Rs 150-200 give almost the same performance.
Thanks for the prompt Reply.
I was given to understand that the Bluetooth version also affects the sound ....Currently I think.it is 5.0.
Is it really so ?
I have no knowledge on that .
Manoj
Auris blume HD and Ifi Zen blue are two popular options among forum members, but they are bit expensive options.
Is it really so ?
Manoj
Not sure about Bluetooth versions affecting sound but all I know is that the latest versions has better connectivity. It all depends on the quality of the source used for playback.
What's the feedback? I also would like to order one. I was thinking of going to iFi Zen Blue but bit skeptical due to its cost..
i use SA acoustic to pm6006 and also SMSLSU-8 DAC to pm6006.
with SA acoustic the sound is loud and better bass than DAC.
I use bluerigger optical cable for SA acoustic phoenix to pm60006
