Hi Vinod
Suggestions are plenty, however, you need to be more specific.
1) Connectivity thru HDMI or analogue?
My TV has both an HDMI as well as analog input.
I don't wish to spend much money on it as I will not use it much. A few thousand would be fine but I will consider a higher one if it sounds good for which I will save for sometime before buying. Of course, I don't want to spend more money if it is not required to be spent as I have been spending lots of money on other stuff so savings would help..
3) Region free for Blu ray/DVD is a must?
I am not very clear on this. As I said above almost all my movie VCDs and DVDs were all made by Indian companies. I usually don't buy Hollywood disks and prefer to get their soft copies from friends/net to view them. I don't know if this is really a must for me.
4) What do you plan to connect it to like AVR etc?
No I don't intend to connect it to an AVR as I don't have or want a HT setup. I will probably connect it to my stereo setup (for the audio part) and my TV (for the video part).
5) Existing set up so that other FMs can make suggestions.\
My current setup is as follows:-
TV Setup: LG 32" TV + Tatasky Plus Settop box
Stereo Setup: Norge 2060 amp + Norge New Millenium Mk II Speakers (Arriving next week)
The amp has AUX / CD / DVD inputs only.
I don't remember the TV model number though. It has HDMI and video/audio inputs. The remote menu has four input options HDMI, AV, TV and Component. Its a wall mounted display type so I can't see the rear connections and must be HD compatible as it has a 16:9 resolution setting.
6) What existing software do you have? Meaning DVD/Blu ray/FLACs etc.
I have no Blu Rays and very few FLAC files.
I have 100+ VCDs and DVDs of Indian films in various languages.
I also have hundreds of movies from around the world in digital formats like AVI, DIVX, MKV, MPEG1, MP4 etc.
I also have many Audio as well as mp3 CDs. Some of my stuff is on data CD/DVD also.
Wouldn't mind if youtube could be played with the player (Need not be wifi. I don't mind connecting a LAN connection from my wifi modem).
I hope you will be able to guide me better now with all these details.
