request help deciding on a 32" LCD tv in 30K range
numerouno
bangalore
Hi Folks,
I need some advice on deciding a 32" LCD tv for my bedroom viewing.
aside to pc qty i look fwd to good volume
in connectivity, USB for movies.
my budget is 30K, dont want a lot of LED fancy, since i have one LED 46" in the living room, ...
opinions are most appreciated.
i too did some basic research and figured out samsung LCD 550 and 580 models .. only difference is the volume. but cant decide ..
I am sure 32" is a very competitive market for TV's..
would prefer a VFM product
thanks,
nu
spoke to a samsung dealer .. he is giving 32C550 for 29K or the D550 for 31K , 32D580 for 33K (no goodies / freebies)
any feed back on buying a C550 Vs D550 or rather any of these models and the price point..
thanks,
nu
I suggest you go for the newer D550 since it's only a 2k diff. See if you can bargain down to within your budget, but anyway its just 1k above which I think you should be able to manage.
