nimmagadda
Hello,
First of all a big thanks to HifiVision forum members. This is short & brief review of my first HT SetUp
All pictures related to AVR, Speakers, Remote, Manuals, Bluray's, DVD's are attached at bottom
( I'm sorry for low quality images because pictures are taken during night time)
I have visited following HT showrooms in Hyderabad
1. Home Cinema India (DEMO room excellent)
2. USK Electronics (DEMO room good)
3. Onkyo Sight & Sound (DEMO room good)
4. Cinebels (DEMO room good)
5. Reliance Digital (DEMO room WORST)
6. AudioTeck (City - Rajahmundry, DEMO room Excellent)
Initially I Auditioned HTIB's but they were really lack of sound quality So I moved towards separaters
AVR's Auditioned : Yamaha, Onkyo, Denon, Pioneer, Marantz
-> Finally purchased Yamaha RX V373 (MRP Rs.24,000/-) from Local Dealer
(Each and every receiver has more or less similar features & produces similar sound quality)
Speakers Auditioned : Jamo, Boston Acoustics, JBL, Polk Audio
-> Finally purchased Boston Acoustics Soundware XS 5.1 (MRP Rs.24,000/-) from Hifimart
( Boston XS is better than Polk Audio Black Stone & JBL Cinema 300, JAMO is good but my budget is limited considering a startup system)
Cables used : 2 HDMI (DAC) + 30 Meter Speaker Cable (DAC) = Rs.6700/-
The reason why I chosen them is based on High Quality Sound @ Low Budget (Startup HT System)
My Room size is 20x12
My TV is Sony 32" LCD
My Bluray Sony BDP S190
Purchased Avatar (Bluray) and DVD's Diehard 4.0, Indiana Jones (Crystal Skull) and some telugu movies. If you are from Andhra Pradesh then telugu movies like Urumi, Simha, Adhurs are good for 5.1 DTS/Dolby effects
Installation is done by myself within 2-3 hours
Yamaha Receiver has excellent convenient features & options. I think it has more than enough features
Really Boston Rocks but I still can't found how these little speakers are able to produce a BIG SOUND. The Sub Woofer is cracking my house shacking walls. Simply what I can say is it's a pure natural sound coming from these speakers. There is NO distortion and NO noise coming from these speakers even if I kept volume to 100%
I watched Avatar(Bluray-DTS HD-MA) completely (75% volume) and felt I was in IMAX hyeah:
But don't expect rich sounds that comes from higher end systems because I auditioned JAMO THX series which sounds richer than Boston
Finally I found these things after using this HT for 30 days (these are just my opinions)
1. HT's are most likely only for Movies and NOT for Music why because of music files like mp3 contains bitrate of 320Kbps but movies with DOLBY/DTS contain 488/755 kbps and Blulray's 1550 kbps(DTS HD-MA). So larger the bit rate can give you a great sound quality
2. Bluray's & DVD's produce similar sound quality. I never seen the difference between sounds produced by DTS & DTS HD-MA. So if your TV screen size is below 50" DVD's are enough and Bluray's are recommended only if you use a BIG Projector screen since bluray's deliver 1080p content
3. Neglect inbuilt USB feature on AVR's because you can use this USB feature from DVD/Bluray players. Because you can save nearly Rs.3000 avoiding this usb feature in AVR's
Lastly thanking you one and all for your support............
