So am looking at buying a 32 inch hdtv and am looking at these two models and cant seem to figure out and major changes. Can anyone enlighten me about them? Also how's lg 32lk450? Any other good full hd hdtv in this range?
I think samsung 32d550 is 2011 model where as 32c550 is old. But there is few technical difference. 32d550 supports
Allshare (Powerd by DLNA)
Smart Phone Remote support
Wireless LAN Adapter Support
One Foot Connection
ConnectShare (USB2.0)
Wide Color Enhancer Plus
on the sound front it supports
Dolby Dolby Digital Plus / Dolby Pulse
SRS SRS TheatreSound
dts 2.0 + Digital Out
Sound Output (RMS)
Speaker Type Down Firing + Full Range
I am not sure One Foot Connection and Smart Phone Remote Support support is supported in D550. It might work in C550 as well. All the above mentioned features (there is no "feature" as "Sound Output (RMS)" - Its just the specification of sound power output).
As far as I know, no major difference.
Here is a feed back of LG 32lk450 from one user from avs forum : http://www.avsforum.com/avs-vb/showthread.php?p=20364774
go for sony 32 cx320. I bought it yesterday after extensive research and comparing same price group models from LG and Samsung. It can play mkv, mp4, avi, divx HD files.
If the best picture quality is your concern rather than unnecessary features, then go for it.
price 29900/-
The colour is deep natural and pleasing in the eyes. Best black level in this category. I have played 1080p Lord of the rings in both samsung and sony. Samsung image processing in this category is not better than sony, The sound is also good compared to other LCD.
It seems so just rebranding the same ,I was expecting audio return channel in hdmi,5.1 audio support in digital optical output,Usb3,Picture clarity improvement.
price 29900/-
Even I feel its just cosmetic changes Samsung has done for this year's models like smart hub, etc. ARC might be there (need to look in the manual) as they are boosting of HDMI 1.4, however like last year, ARC and Optical output might still carry 2.0 PCM for any HDMI based audio.
