samsung 40h5100 or Sony KLV-40R482b
Onlydudeonly
Guys,
Confused between these two,
Need help.
1) Samsung 40h5100
2) Sony KLV-40R482b
Suggestions in terms of picture quality?
Guys,
Need help.
1) Samsung 40h5100
2) Sony KLV-40R482b
Don't buy Samsung H5100. I bought H5100 in May 2014 and Panel problem occurred within 2 months. changed the panel twice and no use. So finally got full refund a week back and sday I bought Sony W700B. I would suggest you Sony R482B. Its Picture Quality is definitely superior than samsung RH5100. If u can bargain a bit more you can very well afford 42W700B. Apart from smart options, both R482B & W700B are similar with slight improvement of PQ in W700B. If u don't need smart options u can very well go ahead with R482B. Good luck.
