Samsung 51d550 pc to tv Project
mabhi10
hey i am big fan of 51d550 i have grew my expectation of watching movies from my pc to tv how can i do them using wifi?
1)Buy samsung wifi usb dongle
2)Install samsung allshare software on your pc
3)Now you can watch movies through wifi
Is any specification required i.e. speed or trasmision etc?
where is samsung dongle sold ?can i use normal wifi router using lan port?
you can use a normal wifi router and it will work fine. for directly streaming from pc to tv the speed will be sufficient because its local wireless lan. you can buy samsung wifi dongle in any samsung dealer, costs about 3k which u plug into tv. samsung allshare software should be provided along with the tv itself.
