Samsung 6000 series and above LED
ShaQ.Blogs
pls suggest samsung LCD/LED TV's 6400 series and above that you would recommend. I would prefer not to have 3D in it.
Budget 50K, prefer not higher. Size 42" - 46".
Also, kindly do share the price info if you have it.
Samsung does not make 42" LEDs. It is 40 or 46.
None of those will come in your budget.
Only 40" 5 series LED will come for ~50k.
Needless to say it won't fit your requirement.
Wow. This makes the VT20 & V20 look like an absolute steal!! The high end model of a plasma against LCD. :yahoo: :annoyed:
Price aside, could you recommend a good LCD, that would fits my needs? 40" shd be fine, and if it is 720p no issues. I am looking for good SD & HD performance. Most of broadcast is after all in SD.
