Samsung bdc5500 audio problem
sbhokray
miryalaguda
Guys....
i recently purchased C5500 which is connected to my LG HT system using optical cable after configuration it worked fine i have upgraded the firmware and since then i am not able to get 5.1 audio from any multi channel audio and video files stored on my USB flash drive the DVD and BD are working fine.
Plz help
Check your audio settings. Is it set to pcm? If then set it to bitstream so that the audio processing is handled by the htib. If that doesn't work then check whether the older firmware is available.
yes things r fine now
dont realy know what went rong
when i tryd to play the same clips today in the morning it is working great
any way thank you sooooo much guys
