Did you try resetting it? I remember the same thing happened to my Dad's Clip+ twice and both times resetting it brought it back to normal. We charged it for about an hour and then held down the Power button for about 12-15 seconds. It booted up and worked normally.
If you have a different Sansa player, the reset procedure will be different. You should find instructions on Sansa's website.
