Second TV.
atul_d1975
India
I have dish tv truhd receiver.
I bought second tv for bedroom.
How to get connection from dish tv tru hd receiver to second tv.
same channel on both tv no problem.
connection via RCA or hdmi.
FROM RECEIVER OR FROM 1ST TV.
Depends upon the distance between 2 Tvs.
If not too much you can use long component / composite cable with 2nd TV. But you need need to first check that these connections work simultaneously while HDMI is also working.
Else you can use RF out cable. The advantage is that you will get audio signals as well from single cable and it can be as long as you want.
I had done this using RF but I guess if you have a spare composite or component video, they also should work. RF is simple since you will be running a single cable for audio + video but has the most inferior quality............but on a 32inches in the bedroom, should be fine.
Distance is approx. 15 meter.
is it possible to put HDMI cable the reason i am asking is of HD quality.
If yes where to connected HDMI CALBE on 1st TV.
I have Panasonic 50" inch tv in drawing room.it has 3 HDMI interface.
TV has HDMI-In only. There is no HDMI out.
15m HDMI cable can work but you will need an HDMI splitter and one short (< 1m) HDMI cable. Connect the splitter as follows:
STB (HDMI Out) ==> Short 1m HDMI cable (new) ==> HDMI-In of HDMI Splitter (new)
HDMI-Out-1 of HDMI Splitter (new) ==> original HDMI cable ==> original Panasonic TV
HDMI-Out-2 of HDMI Splitter (new) ==> 15~20m HDMI cable (new) ==> new TV in bedroom
2nd (cheaper) option:
1. Buy 15m of component cable (with Red-Green-Blue RCA leads) and 15m of RCA audio cable (with White and Red RCA leads)
2. Connect one end of both cables to STB and other to TV.
3rd (cheapest) option:
Warning: Using this option, you will not get HD
1. Buy 15m of RCA audio+video cable (with Yellow, White and Red RCA leads)
2. Connect one end of cable to STB and other to TV.
