What filler did you go for? Or none?
The build is done .However the enclosure needs re-work./rebuild.whats the rest of your setup like ?
have you finished the build ?
rgds
That looks risky with someone accidentally pushing it.Used 3 wood screws .Speaker placed on the head of the wood screws .Temporary till i consider professionally made stands.
First order as defined in xrk in diy audioWhat filler did you go for? Or none?
HThere are some excellent MTM designs for the Daytons as these beam a lot above 2 khz and are very difficult to control over the xo points
Hence followed a spkr and XO that was well documented in diy audio forum
Any suggestions on which brand of speaker available in India would you drive with these .I was looking at elac UB5 ?.My source ipad+DragonFly dac is a limiting factor. I could not get the dayens bs spkrs.Very nice amplifier that one...
