Sennheiser HD 598 V/s RS 180 V/s RS 170 Mini Review
techboy
New Delhi
Sennheiser HD 598 v/s RS 180 v/s RS 170 Mini Review
I went to the Sennheiser office for demo of their headphones.
I preferred RS 180 in this lot because the sound quality was nearly as good as HD 598 but with more thumping bass and very little difference in clearness and clarity, while being wireless. HD 598 was a bit better but not by much.
RS 180 was significantly better than RS 170. RS 180 has more quality and quality of bass compared to RS 170 even with bass boost enabled. The clarity is better with RS 180. It was deeper and more authoritative and with a much deeper and wider soundstage. It wasn't anywhere close to as loud as RS 170 though. And RS 180 didn't leak much sound, not enough to be heard outside the room. HD 598 did leak much more sound though, still not enough to be heard outside a moderately soundproof room.
I proffered the sound signature of the RS 180 the best. The treble of the RS 170 was better than the RS 180 however the mids were best with HD 598, almost as forward and good with RS180 and slightly worse with RS 170.
All three had forward mids. I tried the RS 180 velour pads on RS 170 and the difference between the two was reduced by 30-40%, the RS170 improved a lot by doing just that. And it was also more comfortable.
In retrospect, I would prefer to buy RS 180 over RS 170. The price difference isn't as much as the difference in quality. The difference is not night and day, but certainly noticeable and very significant. Not worth upgrading at full price unless you can sell the previous can for at least 70-80% of the purchase price though.
I recommend the RS 180 over the RS 170 at current pricing. Surround option is decent but just Dolby Headphone isn't bad either. And RS 180 has better bass quantity and quality than RS 170 anyway, partly due to the velour ear pads though. The HD 598 is like marginally better than RS 180 except for thumping bass but then the bass with everything nearly as good makes the RS 180 a clear winner if you can afford it. Especially since it is wireless.
But all this was with the Lehmann amp which costs about 750 pounds. My Asus STX card doesn't power my RS 170 anywhere close. The difference from the Lehmann amp is nearly night and day with it being far livelier, open, with a bigger soundstage and brighter as well. With an STX card you don't get the same effect with a RS 170. It isn't even close.
Recently i got hold of a Sennheiser HD518. Excellent sound, very balanced and neutral. Compared it with HD558 and HD 598. Differences are minimal considering 598 costs 2x times 518. In terms of price verses performance ratio the HD518 is a clear winner.
I agree. But HD 598 has a much wider soundstage. But I agree that HD 518 is pretty good for the price.
