Hi!
I currently have a dedicated phase from my distribution board going into my 3 kva dual conversion online UPS which feeds my audio setup. The other 2 phases are distributed over the apartment. I now wish to install a 25 kva servo stabiliser that will provide stable supply to the entire apartment, including all ACs, white goods, lights and fans.
The dealer has advised that all 3 mains phases should feed the 3 phase servo stabiliser, which will then output 3 phases of stabilised supply. One of these phases can directly feed the online UPS for the audio setup, while the other 2 phases will take care of all other needs via the DB box in the apartment. This would mean that the power supply to my audio supply would go through a 2 stage stabilisation, first by the servo and then by the UPS. The perceived advantage is that the audio setup would get stabilised supply even if either the servo or UPS fail. My concern is that the servo stabiliser may interfere with the pure sine wave or introduce any other kind of noise in the line. I now have the following options:
1. As advised by the dealer above
2. As above, let all 3 phases pass through the servo, but set one phase that goes to the UPS on bypass mode. I am afraid that this too would introduce some interference due to dynamic balancing and components in the servo stabiliser.
3. Supply one phase directly to the online UPS + Get 2 x 10 kva single phase servo stabilisers for the remaining 2 phases for the rest of the apartment needs (2 phase stabilisers are not available). This way my audio setup gets power from the mains without passing through the servo stabiliser. The downside of this option is that I have no backup for my music system when the online UPS fails.
There is not too much difference in the overall cost of the 3 options. Please advise what would be best from the sound quality point of view.
Many thanks
Many thanks
