Solution
Welcome to the forum sadashiv247.
Not sure if you can use any generic bluetooth adapter with your AVR.
Typically each brand has their own model but I am not sure if the tech is proprietary.
Luckily generic bluetooth adapters are available easily and for reasonable prices.
Here is what I found on Amazon: Bluetooth USB Adapter
Regards.
Any Bluetooth adapter with aux out will work. But if you want to utilize the DAC of the receiver, then get chromecast2 and plug it to a HDMI port. It utilizes wifi and is excellent.
If your receiver will have free optical / coaxial inputs, you can get a bluetooth to digital adapter like this. This method also allows you to use the receiver's dac. It will cost around 2K shipped to India, you will also need an optical / coaxial cable as well
You'd rather plug in a ethernet cable to your receiver and get it on the network. This will allow music to be sent to your receiver from any Wi Fi enabled portable device and will sound better than bluetooth for sure.
