Sonodyne HT vs WHARFEDALE vs PARADIGM
SAINATH
chennai
sonodyne HT PACK
sonus 2605v3- 26720k
centrev3- 6450k
di pole surround-12700k
10"rorr 210 sur - 19500k
denon 1713 avr - 31300
sony 3d br p -9800
sony 3d glass - 2800
- 109270/-+cables wires 1500 extra
i asked for 1 lakh the dealer said not poss....
WHARFEDALE HT PACK
FS 10.6 diamond - 49k
centre 10cm -23k
surr di pole - 15k
sub PARADIGM - 39k
pioneer 3d brp - 11k
installation - 5k
wiringcables - 10k
- 1.85l
the dealer is ready for only 10% dis ...
PARADIGM PACK
denon 1713 - 33k
FS para m7 -54.9k
c1 -21.9k
surr s7 - 28.8k
sub para - 39k
pioneer - 11k
inst etc - 15k
188.6l
only 7.5% dis..
pls advice what to go for ..
i auditioned all the above 3 ...wharfedle was best but more budget ...
so pls advice... i have to buy it tmw.......can u suggest the best ...
sonodyne HT PACK
centrev3- 6450k
sony 3d br p -9800
WHARFEDALE HT PACK
centre 10cm -23k
surr di pole - 15k
sub PARADIGM - 39k
installation - 5k
wiringcables - 10k
- 1.85l
PARADIGM PACK
denon 1713 - 33k
FS para m7 -54.9k
c1 -21.9k
surr s7 - 28.8k
sub para - 39k
pioneer - 11k
inst etc - 15k
188.6l
only 7.5% dis..
You have started multiple threads for every clarification.... You could have used the old thread where u asked for comparison of Sonodyne Vs Jamo...
BTW you seem to be a in a hurry to decide...Relax buddy...I can understand you excitement....:ohyeah:..Itz quite normal...
If you like Wharfedale's go for it....Buy all the possible gadgets within the budget that you have....Later (in few months) you can add whatever is missing..:clapping:
can i get anybetter price than this...or is the price quoted is best bet,..
if budget is constrain shall i go for sonodyne?
what abt tannoy mercury .. any dealers in tannoy in chennai..
pls suggest ..
sonodyne HT PACK
centrev3- 6450k
sony 3d br p -9800
WHARFEDALE HT PACK
centre 10cm -23k
surr di pole - 15k
sub PARADIGM - 39k
installation - 5k
wiringcables - 10k
- 1.85l
PARADIGM PACK
denon 1713 - 33k
FS para m7 -54.9k
c1 -21.9k
surr s7 - 28.8k
sub para - 39k
pioneer - 11k
inst etc - 15k
188.6l
only 7.5% dis..
If you want to enjoy your HT/music for a long time take it easy, relax think and buy.
We have forum members who have done months of auditioning before confirming the purchase.
In hindi we have saying "SABAR ka PHAL Meetha hota hai" Meaning When you go slow the results are likely to be sweet. And it perfectly holds good here.
Do lots of auditioning.
Pick the best one
First pick the speakers (2 fronts). Add a avr/amp etc. Then a center/sub. Then you can think about surrounds.
Do not buy in a package(5.1 package) even if you get a discount.
Hope this helps. I am sure this will put u in confusion as you are in a hurry. I am sure lot of forum members will concur with my views.
I am not aware where they carry Def Tech.
Def Tech HTIB are popular but components are not easily sourcable in Chennai.
I have heard that they are available in Mumbai. Why not call up the Indian distributor on their site.
